Living With Leaf : My One Year Stats
Discussão técnica do ponto de vista da Engenharia Mecânica
ruimegas
Gestor do Forum
Data de fabrico: 09 jun 2011
Mensagem por ruimegas » 19 mar 2012, 16:41
Achei muito interessante os dados apresentados.
"As most of you know I collect stats after every Leaf trip. Now that I've driven for a year (as of end of Feb), time to look at some stats. Let me know if you want me to chart any other stats.
First, the range vs temperature chart. The correlation is beyond questionable. Estimated Range is calculated as m/kWh * 21.
[IMG]https://lh3.googleusercontent.com/-a-Xu ... s-temp.png[/IMG]
Here is the raw data behind the chart.
[IMG]https://lh5.googleusercontent.com/-4OcF ... ystats.png[/IMG]
Finally, the range histogram. This shows the % of trips with a particular range. A range of 100, for eg., gives the number of trips where the estimated range would be between 95 and 105 miles.
[IMG]https://lh3.googleusercontent.com/-HINp ... -trips.png[/IMG]
Update : Trip distances."
[IMG]https://lh4.googleusercontent.com/-_1eq ... -trips.png[/IMG]
Em: http://www.mynissanleaf.com/viewtopic.php?f=31&t=8265
Data de fabrico: 09 mai 2011
Re: Living With Leaf : My One Year Stats
Mensagem por Filipe » 20 mar 2012, 09:53
Belo trabalho apresentado. :)
Voltar para “Engenharia”
