Menu escondido i3
Re: Menu escondido i3
Boas,
Dos I3 que tenho experimentado, consulto esse menu para saber a estimativa do fabricante sobre a capacidade atual da bateria. Constato que há vários códigos. Seria útil sabermos o seu significado.
Alguém pode ajudar?
Alguém pode ajudar?
- rimsilva
- Proprietário i3
- Capacidade bateria: 60 Ah
Boas. Isto?
To enter the menu, hold down the trip meter button on the side of the instrument cluster screen for 10 seconds. From then on, pressing this button means "next" and holding down the button means "select". (The car must not be charging and un-plugged. Put car in "READY" by pressing start botton. Follow the instructions from here on.)
To begin with you have only these options available:
1 Identification
1.01 Conv. Index (1/mls)
1.02 SWFL 1
1.03 VIN
1.04 HMI Version
2 System test
3 Start roller
10 UnlockTo unlock the following menus, you will need the VIN from 1.03 above. Add the last FOUR digits together (other BMW models require adding the last five digits) to get your unlock code. e.g if your VIN is L12345, your code is 2+3+4+5=14. If that doesn't work, try adding the last five digits.
11 Consumption
11.01 Consumption dist. (l/km)
11.02 Consumption time (l/h)
12 Range
12.01 Range consumption (l/100km)
12.02 Range (km)
13 Fuel Tank/Battery
13.01 tank left (ohm)
13.02 tank right
13.03 tank left (litres) - zero
13.04 tank right 7.9l
13.05 tank total
13.07 display value
13.07 tank phase. 1
13.08 Batt. Kapa. Max. 19.8 kWh (maximum designed battery capacity)
13.09 State of charge (SOC, battery %)
13.10 Batt. Ladung (battery charge in kWh)
13.11 Batt. Anziege (battery meter indication)
14.01 O. Temp. Sensor
14.02 O. Temp. Raw data
14.03 coolant temp
14.04 oil temp
14.05 batterietemp (battery temperature)
15.01 litre counter
15.02 time counter
15.03 distance counter
15.04 kWh-Zaehler ("kWh counter")
16.01 v CAN (km/h)
16.02 v Display (km/h)
16.03 Cruise Control (km/h)
16.04 Rev. Counter (1/min)
17 System Voltage
17.01 Ubatt (V)
18 Accoustics
19 DTC20 Dimming LCD
20.01 LCD temp. Sensor (ADC)
20.02 LCD temperature (C)
20.03 Light sensor
20.04 LCD luminance
21 Dimming PWM
21.01 Dimming wheel
21.02 Display
21.03 Scales/pt. orange
21.04 Underfloor pointer
21.05 Status lights
21.06 Status lights blue
22 CBS (condition based service)
22.01 km/year short term (km)
22.02 service call status
22.03 Limit, time (Month)
22.04 Limit, distance (km)23 Check
24 Correct. Factor (careful!)
25 software reset
Boas Rimsilva,
É isso mesmo.
Só sei o significado de alguns códigos. Confirma?
Significado
1.01 Conv. Index (1/mls) ?
1.02 SWFL 1 ?
1.03 VIN Nº de identificação do I3
1.04 HMI Version
2 System test Teste de sistema, mas qual sistema?
3 Start roller Iniciar o quê?
11 Consumption Esta é fácil Consumo
12 Range Distância
12.02 Range (km)
13 Fuel Tank/Battery Tanque de combustível/bateria
13.01 tank left (ohm) Tanque esquerdo (ohm resistência elétrica?)
13.02 tank right
13.03 tank left (litres) - zero I3 com extensor de autonomia
13.05 tank total
13.07 display value ?
13.07 tank phase. 1 ?
13.08 Batt. Kapa. Max. 19.8 kWh (maximum designed battery capacity) Capacidade máxima da bateria no seu estado atual
13.09 State of charge Estado da carga
13.10 Batt. Ladung (battery charge) Carga da bateria
13.11 Batt. Anziege (battery meter indication) Indicação do medidor de bateria?
14.01 O. Temp. Sensor ?
14.02 O. Temp. Raw data ?
14.03 coolant temp Temperatura do liquido refrigerante?
14.04 oil temp Temperatura do óleo do motor I3 Rex?
14.05 batterietemp Temperatura da bateria
15.01 liter counter Indicador de combustível I3 Rex
15.02 time counter Relógio
15.03 distance counter Indicador de distância
15.04 kWh-Zaehler ("kWh counter") Consumo em kWh?
16.01 v CAN (km/h) ?
16.02 v Display (km/h) ?
16.03 Cruise Control (km/h) Velocidade cruzeiro
16.04 Rev. Counter (1/min) ?
17 System Voltage Tensão do sistema
17.01 Ubatt (V) Tensão da bateria?
18 Accoustics Sistema som?
19 DTC20 Dimming LCD ?
20.01 LCD temp. Sensor (ADC) ?
20.02 LCD temperature (C) ?
20.03 Light sensor Sensor de luz
20.04 LCD luminance regulador de intensidade de luz do LCD.
21 Dimming PWM Escurecer PWM?
21.01 Dimming wheel regulador de escurecimento?
21.02 Display
21.03 Scales/pt. orange Escala?
21.04 Underfloor pointer Ponteiro?
21.05 Status lights Estado das luzes
21.06 Status lights blue Estado das luzes azuis
22 CBS (condition based service) Serviço de manutenção I3 de acordo com condições?
22.01 km/year short term (km) Prazo por km ou ano
22.02 service call status Estado de chamada para serviço de manutenção?
22.03 Limit, time (Month) Limite de tempo em meses.
22.04 Limit, distance (km) Limite de distancia em km.
23 Check Verificar
24 Correct. Factor (careful!) Factor de correção (cuidado que pode fazer asneira)?
25 software reset reinicialização de software.
É isso mesmo.
Significado
1.02 SWFL 1 ?
1.04 HMI Version
12 Range Distância
12.02 Range (km)
13.02 tank right
13.05 tank total
21.02 Display
23 Check Verificar
- rimsilva
- Proprietário i3
Alguma descrições são auto explicativas outras exclusivas dos REX, aos poucos posso (podemos) ir acrescentando detalhe/explicação....
Sim, do rex parece ser do 11, 12 e do 13.01 a 13.06 (o13.07 está repetido).
Alguém já experimentou a aplicação Bimmer Code no I3?
- rimsilva
- Proprietário i3
Essa aplicação serve para mudar alguns parâmetros de série do i3 e codificar algumas funções "escondidas", mas para funcionar precisa de um adaptador.
Já tenho esse adaptador desde o mês passado, mas estou a aguardar uma actualização de software para resolver um problema que tenho neste momento, assim que esteja resolvido vou testar.
Esse adaptador é o ELM327 que se liga no OBD2?
Quando puder dar feedback seria ótimo, para podermos todos aprender.
