UK - Acham o Nissan Leaf Barato?
Data de fabrico: 09 jun 2011
Mensagem por ruimegas » 04 abr 2011, 16:47
UK - Acham o Nissan Leaf Barato? (Is the Nissan Leaf "Affordable")
"Nissan claim that the Nissan Leaf is "affordable" and I keep hearing that this is not the case given its price of about £26,000 OTR. Well I decided to do the sums and see is Nissan was right.
So we know what it costs to buy the Nissan Leaf, but what does it cost to run it and how long would I need to keep it at average mileage to justify spending out on what, on the surface at least, looks to some to be an expensive car.
I used a comparison with what I thought would be a comparable car. I chose a Ford Focus Titanium 1.6 Tdci. It isn't a true comparison as the specs differ in a number of ways. For example, the Focus doesn't have an automatic transmission option. But I think it is fair to say that on balance, these are pretty much comparable in general standard of spec. Basically, they are both cars with many extras making them both well-specified and comfortable (almost luxury). I have used the accepted average annual mileage of 12,000 miles and used todays diesel price of £1.40 / ltr. Road tax is todays value and for the Nissan Leaf I have used a typical cost of electricity at 12p per kWh.
The Ford Focus is quite frugal in its fuel consumption getting 65mpg on the combined cycle. I think it is fair to say that there are cars that can do better than that but not many and not by much. In fact most would use more fuel than this and some cars, particularly older ones, might use double. Nevertheless, for the sake of making this as fair a comparison as I can I shall stick to all the figures for the Focus.
The Nissan Leaf has a 24kWh battery that runs for 100 miles but this is more like a maximum figure. A more typical range might be 80 miles giving a power use of 0.3kW/mile so this is the figure I will use. Road tax is zero of course.
Insurance is about the same for each and servicing a bit less for the Nissan Leaf but these figures are similar enough not to have much difference between them so I have not included them in the calculation.
Well, after doing the sums it is rather surprising indeed. It turns out that using the figures above, at todays prices and average mileage, the Nissan Leaf is actually cheaper own after 8 years. Use more likely figures for a car of this size and it is even more surprising. Using 45mpg and a more typical £155 road tax then the break even point is just 5 years.
So, keep your car for 5-8 years and you are actually better off owning a Nissan Leaf than a Ford Focus Titanium 1.6 Tdci and this is at todays prices. So, what do you think? Are fuel prices going to remain at £1.40 a litre for the next 8 years? I would say no chance! I can see fuel prices going steadily up given the unrest in the middle-east and with the government commitment to reduce CO2 emissions. So what is a sensible fuel price for 8 years time if it is £1.40 / litre now? I don't think £2 / litre is unreasonable. This represents just a 5% rise year on year. So, if we plug in a price escalator for both cars of 5% per year to take diesel to £2 and electricity to 20p/kWh in 8 years then things look even more rosy for the Nissan Leaf. Now the break even point is just 4-7 years.
It is not that unusual for people to keep their car for more than 4-7 years or for a normal family car to do more than 12,000 miles a year.
So, whilst I accept that it might not be affordable for many given that it requires a higher up front cost, or that you do much less miles, but please, don't tell me that the Nissan Leaf is not affordable. It clearly is..."
Em: http://www.leaftalk.co.uk/entry.php/14- ... dable-quot
batalha
Re: UK - Acham o Nissan Leaf Barato?
Mensagem por batalha » 04 abr 2011, 18:54
Adaptando á realidade portuguesa, parece ainda mais favorável ao Leaf, visto os outros carros serem ainda mais caros, em comparação, por causa do IA.
Contando com os carregamentos nocturnos e contador bi-horario! Tá pago ao fim de 2anos :?: :roll:
CarlosOliveira
Mensagem por CarlosOliveira » 05 abr 2011, 00:11
batalha Escreveu:Adaptando á realidade portuguesa, parece ainda mais favorável ao Leaf, visto os outros carros serem ainda mais caros, em comparação, por causa do IA.
Batalha, acho-te muito optimista... Deverei fazer cerca de 22000km/ano no LEAF e não espero grande retorno antes dos 4 ou mesmo 5 anos... Por isso digo, não fosse o incentivo (que tende reduzir a supervalorização do LEAF nesta fase) não compraria um EV ainda... Mais, no meu caso, a chegada do LEAF, vai "encostar à box" um monovolume que consome 6,5 L/100 e que só circulará ao fds e em casos especiais.
CarlosOliveira
Mensagem por CarlosOliveira » 05 abr 2011, 00:29
Se não repara: um seat leon com as caracteristicas semelhantes ao LEAF (equipamento, motor 105cv, etc) custa cerca de 26k€, o que deixa menos 6k€ para o LEAF. O LEON consome cerca de 4,5l/100 (1.4€/l) dá 6.3€/100. O LEAF fará cerca de 1.5€/100 o que dá uma dif de 4,8€/100. Se dividires 6k€ por 4.8 dá, tens uma diferença para 125000 km. A 25000km/ano, tens 5 anos.
É claro que não levamos em linha de conta muitos outros factores (IUC, manutenção, silêncio, etc) mas também não contamos que ao adquirir um VE estaremos sempre limitados em termos de autonomia, por muito boa que seja a rede de carga. Em suma, ao adquirir um VE temos que fazê-lo com base noutros critérios que não puramente economicistas, isto se não quisermos "tapar o sol com a peneira"...
Essiemme
Mensagem por Essiemme » 05 abr 2011, 09:43
Carlos,
Permita-me perguntar-lhe se não valerá fazer as contas tendo em conta um aumento constante do preço dos combustíveis, quanto custará o litro de gasóleo daqui a 2 anos e meio ????
Talvez essa curva não seja tão linear, mas um pouco mais exponencial...
11 Barras.
+ de 222.800 KMs
+/- 84,55 SOH :|
Mensagem por ruimegas » 05 abr 2011, 10:51
Essiemme Escreveu:Carlos,
Estou a gostar do diálogo :D :lol: ...este fórum é um espectáculo :lol: :lol:
Cumprimentos
Seal
Mensagem por Seal » 05 abr 2011, 14:54
Quanto custa um CB como o do Leaf no Leon?
batalha
Mensagem por batalha » 05 abr 2011, 15:16
Claro que o meu comentário não reflete o que penso, simplesmente aproveitei a onda, e fui na crista 8-)
Eu acho que o Carlos tem toda a razão, e qualquer cliente que ao comprar o Leaf, mantenha o seu actual veiculo apenas por se tratar de um eléctrico, Faz seguramente mau negocio! Esta sim é a minha opinião.
batalha
Mensagem por batalha » 05 abr 2011, 15:22
A resposta para essa pergunta ninguém sabe. Mas deixo outra pergunta!
Quanto custará o equivalente ao Leaf daqui por 4 / 5 anos? Já agora, que custo/km devemos atribuir ao desgaste das baterias?
Mensagem por ruimegas » 05 abr 2011, 15:31
batalha Escreveu:
Se as baterias tendem a ter 80% ao fim de 5 anos de utilização normal, e se fizermos 15.000 kms ano quer dizer que 15.000 kms = 4% de desgaste ou seja, como dizia o outro, é só fazer as contas ....;) :lol: :lol: :lol:
