Arrefecimento global para os proximos tempos
Um lugar para discutir questões ambientais que dizem respeito à electrificação do automóvel.
mikexilva
Moderador Global
Mensagem por mikexilva » 10 set 2013, 12:46
Mais um episódio da meteorologia online ou será apenas a preparação para as filmagens do Ice Age 5? :P
Seja como for eu sempre tive preferência pela isenção de fumo do que a isenção de calor nos motores eléctricos...
http://www.naturalnews.com/041981_globa ... oling.html
Massive expansion of ice proves global warming alarmists wrong
Now the summer of 2013 is over, and you can't argue with the satellite imagery of ice. Those images, shown below, reveal over one million square miles of new ice being formed in just the last year. That's an increase of 60 percent over the previous year, reports the Daily Mail.
Here's the satellite imagery they published, showing the expansion of ice:
[IMG]http://www.naturalnews.com/gallery/arti ... g-2013.jpg[/IMG]
As you can see from the image, the coverage of ice in the August, 2013 image (on the right) is vastly increased over the August, 2012 image (on the left).
Now, I wish I didn't have to actually state the obvious in an article, but warmer temperatures would cause ice to melt, thereby resulting in LESS ice, not more.
Thus, the presence of rapidly increasing quantities of ice is proof that temperatures in the region are falling, not rising. That is, unless you believe in magic in the same way that so many "scientists" apparently believe in magic. What magic? The magic that somehow results in higher temperatures resulting in MORE ice formation. That sort of magic requires an elaborate magic wand, a set of finely crafted voodoo dolls and a bunch of tabloid astrology scrolls to pull off.
O artigo é mais extenso, mas lembrei-me que alterações à salinidade da água pode interferir com a formação de gelo, e realmente alguém comenta nesse sentido no fim do artigo:
Mike Lashewitz
What we recognize down here in the lower latitudes as "global warming" is nothing more than GEO-Engineering. Chemtrailing adds to the green house effect over our lands and we then see freak weather (manipulation) as well as higher temperatures.
In 1994 science warned of an impending ice age then in 1996 chemical spraying began on a large scale. What we have witnessed is increasing temperatures in our climate zones since then.
One of the major reasons for new ice forming is because the Atlantic salinity conveyor has almost failed because of the damage to the Gulf Stream. Look at the facts regarding extreme winters in Britain and the north because the gulf stream was destroyed by the BP oil debacle.
Look at the temperature changes and how the gulf stream no longer goes as far north. Just ask the people of Britain.
A failure in the salinity conveyor will bring about a rapid iceage.
Re: Arrefecimento global para os proximos tempos
Mensagem por mjr » 10 set 2013, 13:30
Só tretas na notícia...
Só porque ficou 1Mkm^2 acima do ano passado não quer dizer que a extensão de gelo não continue, em média a descer. Os "céticos" acham que a área deveria descer monotonicamente, ou seja em que cada ano teria sempre menos que o anterior. Isso é praticamente impossível pois seria necessário que o ritmo de descida fosse maior que a variabilidade natural.
Malm
Proprietário i-MiEV
Data de fabrico: 31 mar 2011
Mensagem por Malm » 10 set 2013, 14:00
Não deixa de ser um facto surpreendente. Afinal os ursos polares, este ano, não vão ter de andar à porrada para terem o seu território. Gostava de saber se na antártida aconteceu o mesmo, e nos glaciares. Se tal não aconteceu, então alterações na corrente do golfo ou na salinidade podem ser fatores importantes.
mikexilva
Moderador Global
Mensagem por mikexilva » 10 set 2013, 14:41
Também pode tratar-se de um efeito local (e como diz o MJR) depois na media global a coisa continuar a aquecer, todos sabems que há invernos que temos menos frio ou menos chuva de um ano para o outro e há verões que temos menos calor ou muita chuva, mas depois nessas alturas vamos ver as noticias de outras partes do mundo e as coisas estão uma calamidade completamente ao contrario do que aconteceu numa zona mais restrita... uma coisa é certa, este ano a Agua do mar no Algarve para os lados de Espanha estava uma maravilha (27 graus de tarde muitos dias consecutivos em Agosto;).
Para não falar nos episódios das micro algas etc...
Mensagem por mjr » 10 set 2013, 15:08
O fator foi mesmo o tempo. Este ano foi muito tempestuoso no pólo norte e por isso a luz do Sol que chegou ao gelo não foi suficiente para igualar o ano passado. Mas mesmo assim está MUITO abaixo da média dos últimos 30 anos!
Por exemplo, o gráfico da área de gelo:
ou um gráfico da extensão do gelo:
Este ano foi o ano em que a extensão de gelo do lado do Atlântico foi menor, pelo que a corrente do Golfo chegou mais perto do pólo. Isto quer dizer que a corrente está mais forte e não mais fraca. E está mais forte porque há mais energia no Atlântico tropical. É preciso ter em atenção que o mar é um reservatório gigantesco de energia, e que a temperatura à superfície é uma fração reduzida da totalidade de energia armazenada. É preciso muita energia para aquecer o Oceano, como provam as águas geladas da nossa costa Oeste.
Para mais info sobre o gelo do ártico há o excelente blog no Neven:
http://neven1.typepad.com/blog/
Malm
Proprietário i-MiEV
Mensagem por Malm » 17 set 2013, 20:57
Estive a ler umas coisas sobre este aumento da área da calote polar no hemisfério norte de 2012 para 2013. Houve uma grande tempestade em 2012 que levou a quebra dos gelos a norte do estreito de Bering, o que fez com que o gelo tenha derretido de forma mais intensa em 2012. Se repararem, na costa leste da Gronelândia, o gelo chegou efetivamente a latitudes menores em 2012 do que em 2013. Este aumento em 2013 deve-se a uma diminuição muito pronunciada em 2012 (explicada pelo acontecimento já indicado). Seria interessante comparar com 2011. Este facto deveria ter sido acompanhado por um aumento dos glaciares e dos gelos no hemisfério sul para ter mais consistência.
Mensagem por mjr » 17 set 2013, 21:50
Depois do recorde de 2007 também 2008 foi um ano de "recuperação", mas em 2010 voltaram os valores muito baixos de extensão e especialmente de volume de gelo (gelo mais fino em médio). De certa maneira era expectável que 2013 não igualasse sequer o recorde de 2012. Ninguém acha que a variação de gelo será monotónica, pois há sempre muita variabilidade de ano para ano.
Deixo aqui o gráfico da anomalia do volume de gelo em relação à média 1979-2011:
[IMG]http://psc.apl.washington.edu/wordpress ... e%28%29%20?[/IMG]
Data de fabrico: 15 ago 2012
Mensagem por RJSC » 18 set 2013, 14:15
Os fãs do petróleo pegam em tudo o que podem para tentar manter o povo na ignorância.
Se as baterias não aumentarem a capacidade e reduzirem o preço rapidamente, ou a sociedade se reorganiza e acaba com os postos de trabalho a 100 ~ 200 km de casa ou vamos ficar muito mal...
Ainda tenho esperança com o fim do petróleo barato (poços convencionais).
mikexilva
Moderador Global
Mensagem por mikexilva » 26 set 2013, 03:15
Dei com este documentario que podem achar interessante:
Chasing Ice:
http://www.youtube.com/watch?v=qU5TW2RFC90
Voltar para “Questões Ambientais”
