Como transferir um viagem planeada para a navegação do Leaf
"Let's say you are surfing the Internet for local events for the weekend. You find something you're interested in and you want to load the directions to the event into your LEAFs NAV. Here's what you do.
Have the events web page handy with the address.
On another browser tab, login to your LEAF owners web page which is http://www.nissanusa.com/owners/login
Click “VIEW LEAF STATUS”
At the bottom of the window click “Launch CARWINGS”
Select “Route Planner” from the menu bar
Click “Plan Your Route”
Type in your starting address, your home address, for example, and press “search”. When it returns, you must select your specific address and it will populate the field.
Enter your destination (copy/paste from directly from the events webpage) and press “search”. Again select the proper address it returns.
Press “Plan Your Route” and scroll down
When it returns press “Forward the route to navigation”
Enter a route name and press “transfer”
You should be returned a “Route has been forwarded to navigation”, press OK
Boot up your LEAF
press the MENU button (right side of NAV)
Press CARWINGS
Press All Information Feeds
Press Route Planner
Press 1 Route Plan 1
Press Map Voice button (right side of NAV) and you are ready to go!
To cancel the route
Press MENU button
Press Route
Press Cancel Route (if your aren't really going there yet)
I find this CARWINGS feature very handy and have used it many times. You can also save specific routes to your address book if you plan on using them again."
Em: http://www.mynissanleaf.com/viewtopic.php?f=38&t=2598
- ruimegas
- Gestor do Forum
